1. The Speedo fails intermittently- lots!!!.
2. Rear fog light indication lamp (dashboard) doesn't work when the car gets warm......but, is fine up to that point.
2.a- rear fog light is hard to switch off, once it is on!
3. SmartNav activates the alarm at 01:30 am!
3a. Any tap on roof just above internal light sets off alarm - Get a dealer to turn the sensitivity down!
4. Object avoidance - does not work!!
5. Trim to base/side of drivers seat keeps coming loose.
6. I'm sure all my shocks are "shocking" fooked.
7. Clutch whine - when cold.
8. Dashboard panel came loose.
9. Alarm packed up.
10. Bonnet was misaligned.
11. Spark Plug failed - Replaced by dealer, but they cross-threaded a cover bolt when refitting.
12. Rear doorcard leather inserts became detached - Replaced under warranty, but did it again (replaced a second time).
13. 'FQ' console badge became detached after 3 weeks.
14. Dealer over-filled the engine oil during the 6 month service.
15. the "X" of "IX" badge on boot it slowly removing itself piece by piece, and spikes is too, is yours Lee?
16. Gearbox blew to pieces after approx. 4k miles. Never felt right from day 1 tbh.
17. Front brake discs warped after 7k miles.
18. ECU locked itself in safe mode - limiting revs and therefore performance.
19. Oil Cooler pipwork became loose.
20. Front driveshaft started leaking.
21. Got in the car this morning and turned the key......engine cranked over, but just would not start. Checked for faults (including OBD) and found nothing - Not even the smell of a flooded engine. So, I called the Mitsubishi Rescue people (very good service btw) who despatched a technician. When he arrived we attempted to start the car again......and after 3 attempts it sprang into life! Took the car to the dealer, who plugged it into their diagnostics equipment......they couldn't find anything wrong (stored or current). Weird!
I think my car is reading this thread!
