by stijoy » Wed Jan 25, 2006 7:47 am
does anyone know how the garages do this ![Question :?:](./images/smilies/icon_question.gif)
![User avatar](./download/file.php?avatar=67.jpg)
stijoy
- Moderator
by jd » Wed Jan 25, 2006 8:07 am
plug in the Subaru Select Monitor.
1mposter is my hero.
![User avatar](./download/file.php?avatar=215.jpg)
jd
by stijoy » Wed Jan 25, 2006 8:08 am
and what does that do?
stijoy
- Moderator
by jd » Wed Jan 25, 2006 8:26 am
They can detect faults & reset as necessary, and change quite a few things (most dealers wont) including idle speed.
jd
by stijoy » Wed Jan 25, 2006 8:31 am
as long as it goes faster thats all that matters
stijoy
- Moderator
by jd » Wed Jan 25, 2006 8:37 am
Cannot adjust parameters i.e mapping.
Why do you need to reset your ecu?
jd
by SPIKE LIKE MIKE » Wed Jan 25, 2006 8:39 am
stijoy wrote:as long as it goes faster thats all that matters
the ecu reset wont make your right foot press harder mate ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
![User avatar](./download/file.php?avatar=99.jpg)
- "Special Needs" constable
by WR1 Bro » Wed Jan 25, 2006 8:40 am
Spike "THE LEGEND" Mike XXX wrote:stijoy wrote:as long as it goes faster thats all that matters
Meoooow! ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
![User avatar](./download/file.php?avatar=19.jpg)
- Site Admin
by stijoy » Wed Jan 25, 2006 8:41 am
how would you know you dont even go over a 100 ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
stijoy
- Moderator
by WR1 Bro » Wed Jan 25, 2006 8:47 am
stijoy wrote:how would you know you dont even go over a 100 ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
65 is my limit.... Got responsibilities these days!
- Site Admin
by jd » Wed Jan 25, 2006 8:48 am
jd
by SPIKE LIKE MIKE » Wed Jan 25, 2006 8:51 am
no need, would of beaten most things by 80,point proved!!lol, no need to embarass them twice ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
by jd » Wed Jan 25, 2006 8:55 am
most things............saxo, nova, escort,......etc....
jd
by WR1 Bro » Wed Jan 25, 2006 8:56 am
jd wrote:most things............saxo, nova, escort,......etc....
But not a Type R....
- Site Admin
by jd » Wed Jan 25, 2006 8:58 am
jd
by marky mark » Wed Jan 25, 2006 9:38 am
select monitor is how the dealers do it, but you can do it yourself. If you use this procedure (pretty sure its the same on new age) you will also get the CEL light flashing to say all ok, or give you a code that a sensor is fubar. I use this procedure quite often and if you have any little niggles it normally sorts it or points you in the direction of the knacked sensor. 1. With engine at operating temp, turn engine off. 2. Locate the 2 ECU check connectors (under the steering column, consisting of a BLACK male and female and a GREEN male and female connector) NOTE: sometimes they are taped over/together. With Ignition OFF connect Black to Black, and Green to Green 3. Turn ignition ON (DO NOT START ENGINE) Depress the accelerator pedal to floor and hold for a few seconds, then release. 4. Start engine and drive for at least 1 min keeping road speed above 11 KM/H (this bit is quite hard to do if you live in a busy resident area!) 5. ECU is now reset 6. At this point, the Check Engine light should start to flash the all clear signal (steady 1/2 second interval flashes) If the check engine does not flash, or indicates some other sequence, there is a possible fault present. 7. Stop the engine, and disconnect the plugs under the steering column. Check here for the various codes/meanings if check engine light appears at any time- http://www.derekcarswell.pwp.blueyonder ... es/ecu.htmIf you just want to purely reset the ECU (and not bother with diagnostics) disconnect the battery for an hour ![Wink :wink:](./images/smilies/icon_wink.gif)
![User avatar](./download/file.php?avatar=238.jpg)
- JPs little helper
by SPIKE LIKE MIKE » Wed Jan 25, 2006 9:45 am
marky mark wrote:select monitor is how the dealers do it, but you can do it yourself. If you use this procedure (pretty sure its the same on new age) you will also get the CEL light flashing to say all ok, or give you a code that a sensor is fubar. I use this procedure quite often and if you have any little niggles it normally sorts it or points you in the direction of the knacked sensor. 1. With engine at operating temp, turn engine off. 2. Locate the 2 ECU check connectors (under the steering column, consisting of a BLACK male and female and a GREEN male and female connector) NOTE: sometimes they are taped over/together. With Ignition OFF connect Black to Black, and Green to Green 3. Turn ignition ON (DO NOT START ENGINE) Depress the accelerator pedal to floor and hold for a few seconds, then release. 4. Start engine and drive for at least 1 min keeping road speed above 11 KM/H (this bit is quite hard to do if you live in a busy resident area!) 5. ECU is now reset 6. At this point, the Check Engine light should start to flash the all clear signal (steady 1/2 second interval flashes) If the check engine does not flash, or indicates some other sequence, there is a possible fault present. 7. Stop the engine, and disconnect the plugs under the steering column. Check here for the various codes/meanings if check engine light appears at any time- http://www.derekcarswell.pwp.blueyonder ... es/ecu.htmIf you just want to purely reset the ECU (and not bother with diagnostics) disconnect the battery for an hour ![Wink :wink:](./images/smilies/icon_wink.gif)
go on pop's!! i dare ya ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
by stijoy » Wed Jan 25, 2006 9:46 am
its just that dave had his done and it has transformed his car, and he knows some others that have had it done with equal success, so i thought i would give it a go.
stijoy
- Moderator
by WR1 Bro » Wed Jan 25, 2006 9:49 am
I had mine reset... different car afterwards!
I thought you were talking yours in the other day to have it reset Pops?
- Site Admin
by stijoy » Wed Jan 25, 2006 9:55 am
WR1 Bro wrote:I had mine reset... different car afterwards!
was going on mon, but hurt my arm so got it booked in for 12 today
stijoy
- Moderator
by SPIKE LIKE MIKE » Wed Jan 25, 2006 10:02 am
stijoy wrote:WR1 Bro wrote:I had mine reset... different car afterwards!
too much ![Too funny :toofunny:](./images/smilies/too funny rofl.gif)
by marky mark » Wed Jan 25, 2006 10:06 am
If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
- JPs little helper
by stijoy » Wed Jan 25, 2006 10:07 am
marky mark wrote:If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
if you come i have a feeling you will be doing quite a few. ![Big ok :ok:](./images/smilies/bigok.gif)
stijoy
- Moderator
by WR1 Bro » Wed Jan 25, 2006 10:19 am
stijoy wrote:marky mark wrote:If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
Bring your spanners Mark... I've got a cold air induction, zero sports radiator plate, zero sports intercooler air flow thing, defi's etc that are waiting to be fitted!! Have I told you that I LOVE YOU Mark?
- Site Admin
by stijoy » Wed Jan 25, 2006 10:35 am
WR1 Bro wrote:stijoy wrote:marky mark wrote:If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
DEFI'S ![Big ok :ok:](./images/smilies/bigok.gif)
stijoy
- Moderator
by WR1 Bro » Wed Jan 25, 2006 10:38 am
stijoy wrote:WR1 Bro wrote:stijoy wrote:marky mark wrote:If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
Just joking mate... I'm skint!
- Site Admin
by stijoy » Wed Jan 25, 2006 10:47 am
WR1 Bro wrote:stijoy wrote:WR1 Bro wrote:stijoy wrote:marky mark wrote:If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
Just joking mate... I'm skint! ![Eek! :eek:](./images/smilies/eek.gif)
stijoy
- Moderator
by WR1 Bro » Wed Jan 25, 2006 10:48 am
stijoy wrote:WR1 Bro wrote:stijoy wrote:WR1 Bro wrote:stijoy wrote:marky mark wrote:If i make it to the RR Day (ex mrs will let me know tonight bro ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif) ) i will reset it for you, takes 5 mins and as said, can make the car like new again.
I wouldn't be so cheeky to ask someone to fit all that stuff either!!
- Site Admin
