please please help
Postby WR 1mposter » Mon Apr 12, 2010 9:41 am
CAVEMAN wrote:fudge it...Exe-Tc it is then.... top mounts too you reckon?
I've got the adjustable topmounts on the front, some reason the rears are not, maybe this is the norm on road cars, but you get more road noise, not that you could here with a 3" decat :lol: and a slight knock when travelling over rough roads such as we have here in britain at the moment.
I got them fitted by Exe-tc themselves, based in Exeter they are 80miles from me.
Postby CAVEMAN » Mon Apr 12, 2010 4:59 pm
you wouldn't happen to have your set up geometry would you? Did they set it up different to the 'normal' set up..
prompts yet another wheel alignment thread!! :lol:
Postby WR 1mposter » Tue Apr 13, 2010 5:48 pm
I do somewhere, will try an find it for you !
Postby adiboy » Tue Apr 27, 2010 6:22 am
hi, took your advice guys and put two new rear shocks on. carnt believe the differance it made, no knocking now and car drives loads better, thought it was diff but no it was shocks. had a whineing noise and done the n/s rear bearing. also had an idle problem that turned out to be air flow meter. just seemed everything went wrong at once but car sorted now and loving it
MANY MANY THANKS FOR ALL YOUR INPUT GUYS
adi
escort ghia
maestro efi
rover coupe
montego turbo (oh yes)
impreza type r
evo 6
focus st 225
impreza wr1
adiboy
Postby Crockel » Tue Apr 27, 2010 7:01 am
adiboy wrote:hi, took your advice guys and put two new rear shocks on. carnt believe the differance it made, no knocking now and car drives loads better, thought it was diff but no it was shocks. had a whineing noise and done the n/s rear bearing. also had an idle problem that turned out to be air flow meter. just seemed everything went wrong at once but car sorted now and loving it
adi
That's great news- I am pleased to hear it is all sorted.
Lee
Crockel
Postby WR 1mposter » Tue Apr 27, 2010 8:55 pm
CAVEMAN wrote:you wouldn't happen to have your set up geometry would you? Did they set it up different to the 'normal' set up..
Cavey, this is what the came was done to when originally fitted, but when I change it to the new stuff I have feeling it was set up different !
Road Height F 350 mm R 335 mm
Toe in/out F 1.0 mm in R 1.0 mm in
Caster Standard
Camber(neg) F 2.0>2.5 deg R 1.0>1.5 deg
Postby CAVEMAN » Wed Apr 28, 2010 9:38 am
cheers pal...never got a read out with my set up, just left them to it, so will check the numbers again when I sling the new struts on.
Previous
