Cars been parked up for three weeks no faults knocks bangs or grinding noise when last used. Went for a drive Saturday and noticed a grinding noise when Corning left or right. Initially thought it was coming from the front, but noise or grind is more evident on near side rear. Sounds like brake back plate rubbing or small stone trapped? The car is perfect in a straight line no noises
I have stripped back brakes removed discs to checked if handbrake shoes faulty or sticking, we're slightly over adjusted so assumed this was the cause, adjusted shoes, cleaned and assembled components grinding noise still there on test drive. Stripped front brakes all fine. All bearings checked, no free play or roughness, but the weight of the car when cornering could have an effect ie movement? I have applied both foot brake and handbrake to see if that would eliminate the noise or change the tone which had no effect.
I have checked wheel arch liners, heat shields, drive shafts, prop shaft anything that could catch moving parts when in rotation also checked shafts for excess movement, centre prop bearing.
Anyone had this problem?
