by jd » Wed Oct 19, 2005 11:11 am
What is the brake fluid capacity on my STI04?
1mposter is my hero.
jd
by jaycee » Wed Oct 19, 2005 11:49 am
Till it's up to the MAX level
jaycee
- Moderator
by jd » Wed Oct 19, 2005 11:50 am
jd
by WR1 Bro » Wed Oct 19, 2005 11:57 am
jaycee wrote:Till it's up to the MAX level
Wise arse destroying threads again. You and Spike are both the same. If you don't know then don't try and be clever. New sensible Stu as a mark of respect to Brian. See, I can do it!
- Site Admin
by jaycee » Wed Oct 19, 2005 12:03 pm
Have a word, the capacity is up to the MAX level, strictly speaking my answer is factual and correct It probably takes under a litre to fill it from empty.
jaycee
- Moderator
by WR1 Bro » Wed Oct 19, 2005 12:07 pm
jaycee wrote:Have a word, the capacity is up to the MAX level, strictly speaking my answer is factual and correct It probably takes under a litre to fill it from empty.
Here's a few words:- "Smart arse pedantic wise boy lard arse"
- Site Admin
by marky mark » Wed Oct 19, 2005 12:44 pm
If you are bleeding out, 1L is enough to ensure the old stuff is flushed through the system, as long as you bleed it properly. If you dont, or your a bit pedantic get 2 litres. You dont have to break the bank with top name stuff, as long as you use dot5.1. I use comma in a pukka big brake set up and no fade or boiling even on a track day.
I think thats what you are getting at.
- JPs little helper
by WR1 Bro » Wed Oct 19, 2005 12:46 pm
I was told you need more than 1 litre if you want to wash through properly?
- Site Admin
by marky mark » Wed Oct 19, 2005 12:48 pm
hang on fella! dont use me in a told you so context!
- JPs little helper
by WR1 Bro » Wed Oct 19, 2005 12:56 pm
marky mark wrote:hang on fella! dont use me in a told you so context!
Not you aswell! Count to 10.... PM from Jaycee will go something like this "don't upset the new people"!!
- Site Admin
by marky mark » Wed Oct 19, 2005 1:01 pm
WR1 Bro wrote:marky mark wrote:hang on fella! dont use me in a told you so context!
Not you aswell! Count to 10.... PM from Jaycee will go something like this "don't upset the new people"!! you wont upset me bro , just trying to give an answer to Jd's question and get the thread back on topic. probably saving you the sh1tty PM actually
- JPs little helper
by WR1 Bro » Wed Oct 19, 2005 1:03 pm
You remind me of Spike... You go off topic and blame me!!
Whilst doing the fluid you might aswell upgrade the hoses... highly recommended in my HUMBLE opinion.
- Site Admin
by jd » Wed Oct 19, 2005 1:16 pm
Thanks for the advice from most people, very helpful.
Spoke to my dealer over lunch & I have ordered 2 litres of Motul RBF600 from Opie Oil. That will leave me some spare.
They will flush the existing Castrol SRF out with cheaper stuff before putting in the Motul.
Also ordered Silkolene Pro-S 5-40 oil.
jd
by WR1 Bro » Wed Oct 19, 2005 1:19 pm
Do the hoses!!
- Site Admin
by jd » Wed Oct 19, 2005 1:23 pm
Hoses & pads done a few weeks ago.
Fluid was changed then for the Castrol which I cant get locally & is approx
jd
