when i set off in the morning or if the cars been parked for a while when i first brake there is a "crack" out of the brakes as if they were jammed,and sometimes if braking while the wheel are angled to a corner?
Posted: Mon Dec 12, 2005 4:31 pm
by marky mark
i assume this is just the pads sticking in the caliper a tad. i get it also but its more noticeable if for ex. i reverse out my drive and apply the brakes therefore settling the pads at the rear of the caliper (but only at 5 mph so cant feel much) then drive up the road and then clunk as the pads shift forward in the caliper.
there is not much clearance, but probably enough to make/feel a clunk ?
Posted: Mon Dec 12, 2005 4:33 pm
by SPIKE LIKE MIKE
cheers
Posted: Mon Dec 12, 2005 4:37 pm
by marky mark
dont qoute me or sue me if you stack it. i did say i ASSUME
Posted: Mon Dec 12, 2005 4:39 pm
by jd
sounds like the pads moving, I have the same.
Posted: Mon Dec 12, 2005 4:44 pm
by The Swede
You washed the car yesterday ? Or mark it with wet brakes ?
I get that after I washed the car. Pads rusted to the discs. (or frozen)
