SubWoofWoofHow much space do these take up in the boot of the car?
Re: SubWoofWoof
Depends what you want in the boot.....Tube or Box or Boxes....and size of this will depend on how big the speaker (s) are! when I had my Type R, I had two separate 12"s fully carpeted and boxed in the booth....they took most of the space up. But they were easy to remove for the big shopping days! R u thinkin of putting Subs in ur 1?
But remember you will also need a decent Amp to run the 10"...otherwise sounds .....And dont forget, you will need good "Tweeters" and mid-range...then decent cabling if you're gpnna do it properly.....and hopefully you will have a decent Head unit to run all these!!. It aint cheap...if you want decent sound.....
What is wrong with the standard head unit? Can I improve it with some gold trim around the edges?
Foool!......Put a Wr1 badge on it...that should do the trick
This is what you want if your after a sub Bro-
http://www.youtube.com/watch?v=_rTmQzG8Kh0 Takes up a wee bit more of your boot than a 10inch though
Holy Mo Fo..... thought my 2 x 12s were baaaad...... Could just imagine Bro in his pimp mobile dropping the beeeeeline
