by SPIKE LIKE MIKE » Wed Mar 07, 2007 4:49 pm
Be helpful please gentlemen......
And if any suggestions as to where I can go to get fitted London and surrounding area?
I have had WRC quote me
- "Special Needs" constable
by WR 1mposter » Thu Mar 08, 2007 12:01 am
[quote="Spike "THE LEGEND" Mike XXX"]Be helpful please gentlemen......
by SPIKE LIKE MIKE » Thu Mar 08, 2007 12:03 am
[quote="WR 1mpostor (aka number 1 moderator)"][quote="Spike "THE LEGEND" Mike XXX"]Be helpful please gentlemen......
by WR 1mposter » Thu Mar 08, 2007 12:04 am
[quote="Spike "THE LEGEND" Mike XXX"][quote="WR 1mpostor (aka number 1 moderator)"][quote="Spike "THE LEGEND" Mike XXX"]Be helpful please gentlemen......
by SPIKE LIKE MIKE » Thu Mar 08, 2007 12:08 am
[quote="WR 1mpostor (aka number 1 moderator)"][quote="Spike "THE LEGEND" Mike XXX"][quote="WR 1mpostor (aka number 1 moderator)"][quote="Spike "THE LEGEND" Mike XXX"]Be helpful please gentlemen......
by danr55 » Thu Mar 08, 2007 9:39 am
WHY do you want it?
- Site Owner
by SPIKE LIKE MIKE » Thu Mar 08, 2007 9:54 am
danr55 wrote:WHY do you want it?
Because its started slipping in 3rd
by SPIKE LIKE MIKE » Thu Mar 08, 2007 9:55 am
by marky mark » Thu Mar 08, 2007 10:07 am
Good price, i think thats the lower spec of the exedy clutch range, but im sure it will be ok if you are only running 'normal' levels of torque.
- JPs little helper
by SPIKE LIKE MIKE » Thu Mar 08, 2007 10:10 am
marky mark wrote:Good price, i think thats the lower spec of the exedy clutch range, but im sure it will be ok if you are only running 'normal' levels of torque.
Normal=up tp 400ft/lb
by marky mark » Thu Mar 08, 2007 10:19 am
In that case stop trying to do things on the cheap.
No organic clutches are officially rated for that, but the reality is the AP ones can run happily up around there.
If you want to rag the car or drag it though, you are at the level where you might want to consider a non-organic one.
- JPs little helper
by SPIKE LIKE MIKE » Thu Mar 08, 2007 10:32 am
marky mark wrote:In that case stop trying to do things on the cheap.
Please explain organic/non organic???? Is one made on a farm ?
by marky mark » Thu Mar 08, 2007 10:46 am
Like it Spike. The friction plate (the bit that grips the flywheel on one side and the pressure plate on the other hence transmitting drive from engine to gearbox) on an organic clutch is made of an organic fibre. These are only OK up to a certain level depending on fibre quality,size,springs etc. After this you have to go to more fancy materials that have more resistance to sliping on the flywheel face. Carbons, ceramics, etc. and then paddle items. The beauty of the organic is it feels nice, its progressive and does not need really high spring rates to work. The materials that can take more torque, are invariably not as nice to drive with. Can be very grabby and need a lot of leg force to operate.
- JPs little helper
by SPIKE LIKE MIKE » Thu Mar 08, 2007 2:25 pm
marky mark wrote::lol: Like it Spike. The friction plate (the bit that grips the flywheel on one side and the pressure plate on the other hence transmitting drive from engine to gearbox) on an organic clutch is made of an organic fibre. These are only OK up to a certain level depending on fibre quality,size,springs etc. After this you have to go to more fancy materials that have more resistance to sliping on the flywheel face. Carbons, ceramics, etc. and then paddle items. The beauty of the organic is it feels nice, its progressive and does not need really high spring rates to work. The materials that can take more torque, are invariably not as nice to drive with. Can be very grabby and need a lot of leg force to operate.
THANKYOU
by danr55 » Thu Mar 08, 2007 3:03 pm
Spike "THE LEGEND" Mike XXX wrote:marky mark wrote::lol: Like it Spike. The friction plate (the bit that grips the flywheel on one side and the pressure plate on the other hence transmitting drive from engine to gearbox) on an organic clutch is made of an organic fibre. These are only OK up to a certain level depending on fibre quality,size,springs etc. After this you have to go to more fancy materials that have more resistance to sliping on the flywheel face. Carbons, ceramics, etc. and then paddle items. The beauty of the organic is it feels nice, its progressive and does not need really high spring rates to work. The materials that can take more torque, are invariably not as nice to drive with. Can be very grabby and need a lot of leg force to operate.
THANKYOU
learn something every day from Mark WHY do u need it Spike?
- Site Owner
by SPIKE LIKE MIKE » Thu Mar 08, 2007 3:22 pm
danr55 wrote:Spike "THE LEGEND" Mike XXX wrote:marky mark wrote::lol: Like it Spike. The friction plate (the bit that grips the flywheel on one side and the pressure plate on the other hence transmitting drive from engine to gearbox) on an organic clutch is made of an organic fibre. These are only OK up to a certain level depending on fibre quality,size,springs etc. After this you have to go to more fancy materials that have more resistance to sliping on the flywheel face. Carbons, ceramics, etc. and then paddle items. The beauty of the organic is it feels nice, its progressive and does not need really high spring rates to work. The materials that can take more torque, are invariably not as nice to drive with. Can be very grabby and need a lot of leg force to operate.
THANKYOU
currently slipping in 3rd mate (maybe a bit too many horses ) Its on its original clutch and has 65k miles on it so its "overdue"
by marky mark » Thu Mar 08, 2007 3:26 pm
You need to budget for a flywheel as well, or a skim of the existing one.
At that mileage, and the fact its been driven while slipping, will mean there is a good chance the mating face will not be very good.
- JPs little helper
by SPIKE LIKE MIKE » Thu Mar 08, 2007 6:35 pm
marky mark wrote:You need to budget for a flywheel as well, or a skim of the existing one.
Where can I get one of them matey? And what sort?
by WR 1mposter » Thu Mar 08, 2007 9:23 pm
Who owns the 99 turbo Spike
by SPIKE LIKE MIKE » Thu Mar 08, 2007 9:24 pm
WR 1mpostor (aka number 1 moderator) wrote:Who owns the 99 turbo Spike
"My Freind" has this problem.......
by WR 1mposter » Thu Mar 08, 2007 9:36 pm
Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Who owns the 99 turbo Spike
"Your Freind" or "your friend"
by SPIKE LIKE MIKE » Thu Mar 08, 2007 9:37 pm
WR 1mpostor (aka number 1 moderator) wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Who owns the 99 turbo Spike
"My Fiend" you "floo"
by WR 1mposter » Thu Mar 08, 2007 9:43 pm
Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Who owns the 99 turbo Spike
numsty
by SPIKE LIKE MIKE » Thu Mar 08, 2007 9:44 pm
WR 1mpostor (aka number 1 moderator) wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Spike "THE LEGEND" Mike XXX wrote:WR 1mpostor (aka number 1 moderator) wrote:Who owns the 99 turbo Spike
numsty
"Probably" ....like they say about Carlsberg in "dripple"
