by Anders_WR1 » Thu Mar 22, 2007 8:30 am
My engine check light came on today driving to work. No activity on the knocklink, although the cold weather did cause a boost spike to 1.7 BAR on the Defi's at point.
I have noticed the 0.5 BAR restriction isn't in place even thought the engine light is on...is that because it's been remapped?
Any bets it's the MAF?
I'll be calling the dealer in a minute to get it checked out.
Anders
Anders_WR1
by WR1 Bro » Thu Mar 22, 2007 8:34 am
I've had this a couple of times on rather spirited drives when the air has been crisp. I never noticed a problem since the car didn't go into safe mode. You will find the engine light will reset itself after three starts of the car!!
What gear where you and at what revs?
- Site Admin
by Anders_WR1 » Thu Mar 22, 2007 9:00 am
WR1 Bro wrote:I've had this a couple of times on rather spirited drives when the air has been crisp. I never noticed a problem since the car didn't go into safe mode. You will find the engine light will reset itself after three starts of the car!!
I booted it in third gear, changed up to fourth until letting off around 6k because of traffic in front. Ok, just started the car four times and the light went off May be that slight over boost triggered some safety mechanism that is disabled if it doesn't see the same condition after three or four starts? A similar thing with engine check light happened to a WRX that came out with us last Sat. He changed down from 5th to 2nd and the car went up to 9,000 rpm briefly. Engine check light came on, although when I met him the next day he said it had gone off by itself. I call the dealer and let them know it's gone off and see what they say. Cheers Anders
Anders_WR1
by Anders_WR1 » Thu Mar 22, 2007 9:07 am
The dealer said a temporary fault condition would allow the engine check slight to disappear after a few engine restarts. He suggested I see how it goes over the next couple of days.
It was probably a bit of overboost caused by cold weather I recon.
Anders
Anders_WR1
by WR1 Bro » Thu Mar 22, 2007 9:30 am
Anders_WR1 wrote:The dealer said a temporary fault condition would allow the engine check slight to disappear after a few engine restarts. He suggested I see how it goes over the next couple of days.
Anders
That would be my guess too!
- Site Admin
by marky mark » Thu Mar 22, 2007 9:54 am
Ann mine, but i would still get them to read the codes just in case. I;m sure there are a lot of sensors that could fail or be playing up that don't necessarily put you in safe mode.
- JPs little helper
by Anders_WR1 » Thu Mar 22, 2007 6:22 pm
No problems on the way home. I'll be carefull next time I'm booting it at 2C (and snowing).
Bro, are you on the standard map? I never had overboost problems before I started modding...
Anders_WR1
by SPIKE LIKE MIKE » Thu Mar 22, 2007 7:31 pm
theonly time I had the warning light and sae mode was on a really hot day!!!
If you've just been mapped GO BACK and get it looked at...during colder weather my cars always ran "better". if it was -32 like where sandy is I can imagine problems with the cold/as he experiences with overboosting.
Id make first call your mapper mate!!
- "Special Needs" constable
by WR1 Bro » Thu Mar 22, 2007 9:43 pm
Anders_WR1 wrote:Bro, are you on the standard map? I never had overboost problems before I started modding...
No mate, standard car. That reminds me, there was something that had to be replaced on the wastegate that caused my engine light to come on. Marky Mark might remember what it is called?
- Site Admin
by danr55 » Thu Mar 22, 2007 10:32 pm
WR1 Bro wrote:Anders_WR1 wrote:Bro, are you on the standard map? I never had overboost problems before I started modding...
flappety sprocket mate, they often cause the issues...
- Site Owner
by marky mark » Thu Mar 22, 2007 10:45 pm
Actuator arm?
- JPs little helper
by WR1 Bro » Fri Mar 23, 2007 8:16 am
marky mark wrote:Actuator arm?
Is that the part that you said was a two min job to replace? If so, that was the fella. Can this be picked up by the ECU?
- Site Admin
