I've found a boost leak at last. I came up with a contraption for testing pressure in the FMIC pipework without the engine running...
I used the hose from a brake bleading kit that's powered from the spare tyre air pressure, then pushed one end through a hole I drilled in a small plastic disc. I used araldite to seal the plastic disc to the hose from the brake kit.
The plastic disc was small enough to fit down the FMIC pipework on the pressurised side of the turbo. I taped this lot in place creating a seal on the plastic disc. I pulled off the silicon hose by the throttle body and taped up the FMIC pipe to seal that end up. So I had a seal at the FMIC pipework by the turbo end and the throttle body end.
I connected the spare tyre to pressurise and I could hear a small leak. I tracked it down to a small gap between the dump valve and the adapter plate that had been fitted to keep the standard re-circ dump valve.
I'm going to order a couple of new gaskets tomorrow and see how I get on. I'm also going to try taking the boost readings for the Defi's from the manifold, rather than the vacum pipe that goes to the dump valve to see if the readings are different.
I know a picture would be easier, but my camera phone is fooked!
Anders
