Its time for some new pads, I've got the Ferrodo DS2500's at the moment, I did have some very slight intermitent judder under heavy braking at Silverstone last week, which was probably down to the level of wear left in the pads, otherwise they've performed very well.
I know there are thoughts that they leave a deposit on the disc and cause brake judder
Martin - what did you end up fitting to yours after the sarga with ASP and the pagids?
I've also seen Mintex quoted for around £100 a set....
I need something that will definately fit, as I need to get them on the car before the weekend, don't have time for any problems.
