F.A.O. MARK.
F.A.O. MARK.
Postby stijoy » Wed Nov 01, 2006 11:15 am
just another question on oil :roll:
earlier in the year we went down to cornwall, we called in at opie oils, as i wanted to get some more 10-40 silkolene pro s,
i ws informed by the main man that i should really be using 5-40 instead :?
when i was going round bruntingthorpe in aug, i noticed that my oil temp was between 115 and 118 :?
now as i am going to be going to the spa,ring trip next year, am a little bit concerened that this might not be the right one :?
would it be better to go back to 10-40, or would you reccomend something that is good for every day driving, and for when you get on these circuits :?
thanks :thumb:
stijoy
Postby danr55 » Wed Nov 01, 2006 11:34 am
you'll be changing the oil again before spa pops... :wink:
Postby stijoy » Wed Nov 01, 2006 11:39 am
danr55 wrote:you'll be changing the oil again before spa pops... :wink:
that certainely answered my questions :roll:
i realise that :wink:
stijoy
Postby marky mark » Wed Nov 01, 2006 12:59 pm
the 5/40 is subarus recommendation for a new age standard car under normal driving conditions. For the classic its 10/40 because the bore/piston clearance is greater.
If you are using the car outside of standard operating parameters and achieving oil temps that high you would be advised to go to at least a 10/40. This will still be ok at winter cold starts as well.
So if you cant be bum to change before and after a track day you want min 10/40.
I was getting 110-115 at Brunters on 15/50 and a new age bottom end but obviously i am making more heat than you with 400 BHP+
For your information, i suffered a big end failure at 118 degrees
Postby stijoy » Wed Nov 01, 2006 5:50 pm
so you would say go back to the 10-40 then mark :!:
will it be ok to switch back to 10-40 after using 5-40 :?:
stijoy
Postby marky mark » Wed Nov 01, 2006 5:54 pm
If you are using it on track then yes put 10/40 in. If you dont (and your car is standard) stick with 5/40
It has no ill affects swapping between grades.
If you want to be a fanny - put in 50/50 of both, believe it not you get 7.5/40! make sure they are the same make and type of oil though
Postby stijoy » Wed Nov 01, 2006 6:00 pm
i think i will go back to the 10-40, next aug then :wink:
stijoy
Postby WR 1mposter » Wed Nov 01, 2006 6:58 pm
RCM put "pro r" in ours Mick, slely for "the ring /spa trip"
I think its 15/50
Also oil temp never went over 110
if I remember right :wink:
but will revert back to 5/40 :wink:
Postby stijoy » Wed Nov 01, 2006 7:02 pm
WR 1mpostor (aka number 1 moderator) wrote:RCM put "pro r" in ours Mick, slely for "the ring /spa trip"
I think its 15/50
so 15-50 for track use, 5-40 for every day driving :wink:
stijoy
Postby WR 1mposter » Wed Nov 01, 2006 7:08 pm
I think its 15/50
Pretty certain it's 15/50...
I did purchase two cans and one is in the boot
of the car ......i will let you know tomoz :wink:
as its cold outside now ...
Postby stijoy » Wed Nov 01, 2006 7:10 pm
ok 8)
stijoy
Postby WR 1mposter » Mon Nov 06, 2006 7:55 pm
Mick its 15/50 sikolene :wink:
but will go back to 5/40 for the winter :wink:
