HID conversionsCan anybody who has HIDs tell me if they're E-marked, and if not whether you've ever been told off at MOT time?
never seen any e-marked and a lot of peeps are going to have ongoig issues i believe as new MOT rules have tightened up on aftermarket lighting..........
HIDI have been told it will fail the MOT if fitted.
I was thinking of getting a set from HIDS4U, they make no mention of MOT's or E-marking. Whenever I've had an MOT they check the beam alignment but I've never seen them check the bulbs or anything...
This is directly from the DVLA site on what an MOT test involves: Lights Condition, operation including HID and LED headlamps for cleaning, self levelling and security. Headlamp aim. Main beam warning light. There are no stupid questions, only stupid people.
Just found this in the official testing manual
MOT testing manual section 1.7 Information - Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system. Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given. Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch. HID lamps may be identified by: taking a few seconds to reach full intensity having a bluish tinge to the light having an igniter module/inverter behind the headlamp having ¡¥DCR¡¦ marked on the headlamp lens. HID headlamps use high voltage and extra care should be taken when inspecting these items. method of inspection Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted. Reason for rejection A headlamp levelling or cleaning device inoperative or otherwise obviously defective. There are no stupid questions, only stupid people.
So if you have HIDs and have washers and self levelling systems then they must work. It doesn't make it clear though if you have to have the washers or self levellers.
I always thought you had to have headlight washers and self levellers if you had HIDs but not sure now... hmm...
As I read it, if they're there, they have to work, but if they aren't, they can't fail you for it? Anybody on here speak MOT? There are no stupid questions, only stupid people.
Its a bit like having a spare wheel and tyre that has to conform in all respects, but if you take it outa the car for and MOT, they cant fail you if its not there.
Balls to it. HIDs ordered and on the way. They'd better be as good as everyone says! There are no stupid questions, only stupid people.
Well the 'two Steves' seem to read it as I do in that if you have the other systems they must work if you don't then they cant fail you for it.
Alyn, have you got some additional info as to these new lighting rules? Not sure what is involved in fitting a HIDs setup, is it a one way system or are they just a set of better bulbs that can be swapped back if required to get through an MOT. Must admit getting back in the WR1 the lights don't seem fantastic compared to the discovery/megane ive been driving since August - neither have xenons/hids.
My thoughts exactly, MOT fail, swap the bulbs back, retest, get home and fit HIDs again.
we have recently had 2x customer cars failed (different stations) for aftermarket HID's...........rules change 01/01/12
Latest manuals here:
http://www.transportoffice.gov.uk/crt/d ... guides.htm Inspection Manual for Classes 3, 4, 5 and 7 Vehicles – Browse Full Download (2.44Mb)(Private Passenger and Light Commercial Vehicle Testing) typical kit: http://newview.en.made-in-china.com/pro ... -Lamp.html http://dohon-light.en.made-in-china.com ... n-Kit.html
http://www.motinfo.gov.uk/htdocs/m4s01000701.htm
This is the section in question from the link above and I still cant see any reason for failing the car for having HIDs if they work properly. Was there a reason in particular that your two customers cars failed for having the HIDs Alyn? Interesting reading
They're illegal if the car doesn't have self levelling ability or headlamp washers isn't it?
I've not had a problem with mine over the last 2 years but we'll see how it gets on this time! Going round corners just got a whole lot faster...
Just what I always thought but cant find that anywhere in writing...?
It doesn't say that, it says IF they're fitted, they MUST work, but in practice it may be difficult to ascertain whether the self-levelling works, so the benefit of the doubt is given. Nowhere does it say aftermarket HIDs or other bulbs will be failed. And if it isn't in black and white, surely the tester can't fail you for it? There are no stupid questions, only stupid people.
well it was down as a fail as the headlamp levelling wasn't working and HID's fitted - also poor / lack of beam pattern was noted..........
ah, I can understand that, my MOT isn't until November, so I'll have to wait until then to see. I noticed HID kits can be bought on eBay for about £50 or less. I've gone for the HIDs4U ones, they say they have no excess glare and are better quality. But I suppose they would say that...!
Suppose you could say they saw you coming I still find it crazy that they are penalising people for improving their vision at night. I can understand if you are blinding everyone then fair play but just for brighter lights that are used normally.. takes the micky really..
Done a bit more digging, this seems to be a nail in the coffin for our HID's.
http://www.dft.gov.uk/vosa/repository/t ... ghting.pdf Although it contradicts the latest MOT Manual
HIDs - fitted!Sod the MOT, if it fails it fails:
Drivers side light, air intake removed and HID bulb fitted Passenger side (tight between battery) Hey presto, let there be light! The ballast isn't secured yet, they are the silver boxes on top of the battery and the other side And the view from inside: They are ace, well worth the 90-odd quid. Best upgrade under £100 ever! The difference on the road is amazing. If you haven't got any, get some! There are no stupid questions, only stupid people.
Bugger Looks like theyre trying to get people to see less, to increase crashes probably to justify speed cameras
My car just failed cause they couldn't get a beam pattern! so put normal bulbs (candles) in passed so will now put the hits back in
HidHave you got a link to the kit you bought thanks
Hid'sI got mine on a group buy from this firm on scoobynet ! good quality and good price !
http://www.superhids.co.uk/hid-conversion-kits.html Always try and get to B from A very Quickly !
hids4u.co.uk or hids4u.com, one or t'other. They come with excellent instructions and I think a 12 month warranty. You want the H1 kit for dip, their site says H4. It's wrong.
