Gearbox and engine oil?
Postby Dayo » Fri Jun 01, 2012 8:46 am
Which oil is best to use for the gearbox and engine? Millers? And which w/w rating?
Thanks
Finally Got My Hands on a WR1 #039. Loving it ;)
Dayo
Postby Dayo » Thu Sep 13, 2012 4:29 pm
anyone?
Dayo
Postby rocko » Thu Sep 13, 2012 8:15 pm
Engine oil = Silkolene Pro R/ Moblie 1
Gearbox = Castrol syntrax ..
:D
"666"
rocko
Postby SteveS » Thu Sep 13, 2012 8:22 pm
rocko wrote:Engine oil = Silkolene Pro R/ Moblie 1
:D
Yep, I would go along with Rocko on that.............if I could keep up Image
SteveS
Postby Dayo » Thu Sep 13, 2012 8:22 pm
Where can i get them from and for what price? I need an oil filter aswell.
Dayo
Postby Dayo » Thu Sep 13, 2012 8:26 pm
What about the W values?
Dayo
Postby Gary75 » Fri Sep 14, 2012 6:19 am
Dayo wrote:Where can i get them from and for what price? I need an oil filter aswell.
I use Fuchs Titan pro race 5w40, if your going to track day the car 10w/60 etc
They state Castrol for the gearbox, but does that have the LSD additive? my last service on the invoice stated LSD oil front and rear diffs replaced.
Castrol is now branded universal, replacing the syntrax label 75/90 oil.
Brought mine from Opie oils
Get your filters and sealing washers from the dealers or shop on ebay, i see some people selling original filters for half the price, worth a look?
I use a magnetic drain plug and also have black hole magnets around the filter, this helps clean up the very fine metal shavings which slip through the filter :wink:
Postby asperformance » Fri Sep 14, 2012 12:40 pm
we carry all in stock............
normally Millers CFS range engine oils, as well as Motul/Shell Racing (multi ester based and far better product than Fcuhs/Silk IMO)
we would normally use CRX gear oils, withstand the heat generated by the electronic diff far better than the Syntrax but can also supply if reuired - you also want a specific LSD rear diff oil........
